I wasnt sure if suppliers could supply them without the VAT on the invoice?you have to be VAT registered to claim back VAT.
Nope, as per most government schemes, you have to claim it back after purchase. 3 months later usually. Hence I never discounted Vat off materials to customers, but treated the Vat as bonus money, otherwise the business would probably have collapsed waiting for the money. So solar at 5% or 0% is a bit of a myth unless you are doing the vat claim for a new build.I wasnt sure if suppliers could supply them without the VAT on the invoice?
Thanks Shaun. I was just doing a few calculations over breakfast and I was thinking a 20kwh battery setup should be able to produce approx 7200kwh per year and of only charged at the octopus go low rate . It would cost approx £850 per yearYou have to buy a system from a vat registered installer, which includes one of the energy saving measures. Solar is one of them. Batteries are not one of them annoyingly. But batteries and solar together including labour would be all invoiced to you at zero vat rate.
As an installer. We pay VAT on the equipment as we would everything else and then on the quarterly vat return. We are claiming for input vat but not for output vat. So the vatman owes us a refund every quarter. Which makes a nice change.
As for batteries and no solar. I unplugged our solar at the end of September and we are running on battery only as an experiment. 13kwh system. Charge at night on edf’s 5 hour cheep period. House runs on battery from 5am - midnight. If we are careful it lasts. If we are not careful, the battery gives up at some point in the evening and then we are taking from the grid at 45ppkwh which is painful. This just makes me want to increase the battery to probably 15kwh.
Will plug the solar back in in Feb probably, I suspect having solar back in the mix will negate the extra battery as we will be going into the dark evening with a higher state of charge.
As for savings. On battery only with an average usage of about 12kwh a day. We spend less than £2 a day. Which is neatly less than the governments £66 a month to all households, so we have no electricity cost at present.
Summer should be mostly solar powered, next winter is the challenge now.
Surely you would increase by more than 2kWh? it wqould advantageous to have a bigger store in the summer and less import from the grid for charing.As for batteries and no solar. I unplugged our solar at the end of September and we are running on battery only as an experiment. 13kwh system. Charge at night on edf’s 5 hour cheep period. House runs on battery from 5am - midnight. If we are careful it lasts. If we are not careful, the battery gives up at some point in the evening and then we are taking from the grid at 45ppkwh which is painful. This just makes me want to increase the battery to probably 15kwh.
Thats what happens on my system, yesterday we started the evening with one car 50% charged, both batteries at 100% and the hot water tank full, the net result was only 10 kWh imported last night during off peak time.Will plug the solar back in in Feb probably, I suspect having solar back in the mix will negate the extra battery as we will be going into the dark evening with a higher state of charge.
My average for January is £2.39 per day and that includes 2 x EV, heatpumps and Immersion heater.As for savings. On battery only with an average usage of about 12kwh a day. We spend less than £2 a day. Which is neatly less than the governments £66 a month to all households, so we have no electricity cost at present.
I'm hoping for this too, I have another roof available and may well add 8 more panels this summer.Summer should be mostly solar powered, next winter is the challenge now.
I think you'll find that you'll have to pay more for your cheap electricity than you can sell it back for. Or at least there will be such a small margin in it that it would take decades to recoup your outlay cost.For 8k you can get approx 20kwh off the shelf battery's. If you add the inverter and gubbins your around 10k. If you then charge them at the cheap rates available.
1 would you have enough charge be able to fill them each day
2 would 20kwh be enough for the AVG household.
3 is it possible to charge battery's at cheap rate over night then sell access back from the battery's during the day.
I think thats a very keen price, £900 per kWh seems nearer the mark.For 8k you can get approx 20kwh off the shelf battery's.
A decent 5kW inverter is around £1700If you add the inverter and gubbins your around 10k.
That depends on your inverter choice, my 5kW Victron charges at 3.5 kW so 14kW is the max available in the 4 hour period.If you then charge them at the cheap rates available.
1 would you have enough charge be able to fill them each day.
I would think around 12kWh would be enough for the average house. Very difficult to estimate, everyone is different and every house is different, you really need to analyse your personal use.2 would 20kwh be enough for the AVG household.
That doesnt work, on Octopus GO for example off peak is 7.5p kWh and on export you get paid 4.5p kWh. Generate, store and use yourself is the best energy advice3 is it possible to charge battery's at cheap rate over night then sell access back from the battery's during the day.
16.7% actually but still a saving. (for every £1200 you pay £1000 saving £200. 200 is 16.7% of £1200)If you go solar you get zero VAT on all of the equipment including the battery, theres 20% saving straight away.
I've just purchased a 4.8kwh pylontech 5000 for £1859 Inc delivery
Would the inverter need to be a smart meter for battery only?
I've not looked into this though I'm sure their are inverters that charge at higher rates
We have 5 people in our home and our usage last year was 6397kwh.
That doesnt work, on Octopus GO for example off peak is 7.5p kWh and on export you get paid 4.5p kWh. Generate, store and use yourself is the best energy advice.
I have no idea about tariffs would octopus agile work?
It's very difficult to predict savings etc. What I can tell you is my experience with actual figures.One major flaw with solar panels as we all know is they need sun light. (Not true obv)
In a year their are approx 8750 hours.
If we say the assumption is half these hours are night time 4375
And Where I live in Sheffield only 1485 are the avg sunlight hours per year.
then it only leaves a short time to be able to make enough electricity toake solar efficient.
Even of you maxed out the panels and inverter the amount of daylight hours doesn't change.
Options.
We add batterys and as proved over the years. The ROI is not great on battery's due to cost and lifespan.
Or
We make loads of spare leccy and sell it back to the grid to cover the costs of when we have to purchase overnight/dull days. Though since the fit payments have gone the payback is very poor.
Or
Get a combo of panels and battery's to try and cover our usage who h in the summer it's brilliant and the winter still quite expensive. It's really a tough balancing act.
Or
As above just purchase battery's and use the cheap overnight rate to charge them.
Obv problem with this is if everyone did it their wouldn't be any cheap overnight electricity ...
I'm starting to think this solar stuff is flawed
Pylontech 5000. Are around £1850 they are 4.8kwh.I think thats a very keen price, £900 per kWh seems nearer the mark.
That seems way below average, good if you can get them at that price.Pylontech 5000. Are around £1850 they are 4.8kwh.
Smart meters are nothing to do with inverters, it doesnt matter what type of meter you have.Inverters. Do they need to be smart meters when you don't have solar panels?
The hybrid inverters will charge up to their specified rate, ditto solar inverters with MPPT chargers.I've hear mentioned on this forum you can get inverters to charge at higher rates. Tbh I think mine is 2.5kwh
To be fair pumps dont take much by way of power to operate, 20kWh per day is a fair amount of power, saving are there to be had. Utilita have a 5.33p off peak rate, if you used 20 kWh per day your electricity bill would be £1.06 per day (theres no standing charge) or £32.42 per month compared to £255 per month for a standard tariff. Under 4 years to break even assuming your £10k to get the equipment etc.We have 5 adult on our house and are quite large consumers. Koi pond ect. W0kwh would be about what I use
There are times where the export payment is really good, there are however lots of other times when import costs are high and export costs are low. You literally have to be on duty to drive your system as required. I use Octopus GO and I know from 00:30 to 04:30 I have 7.5p kWh and from 04:30 to 00:30 I have 29.2p kWh, I just make sure I buy all of my power between 00:30 and 04:30. I have looked at agile many times and I just dont see where I could gain over GO.What does octopus agile or the recent smart tariff offer regards pay ack. Isn't one of the paying back large amounts at peak times
Tariff expires at the end of March when it becomes 12p and 36p, I will be moving to utlitita at that point on 5.33p.You must have a fixed rate on octopus go cos my chargers are 12p and 40p high/low rates.
No problem, theyre not smart in any way just have a built in battery chargerThe bot about smart meters. I had a mind melt. I was going to say smart inverters. IE hybrid inverters
If youre getting more than one, rent a van and go and collect, price is now £1653 BTW.Link to the battery's. Tbh they look like they have come down in price though they charge £80 delivery
https://www.itstechnologies.shop/products/pylontech-us5000-4-8kwh-95-d-o-d-battery-storage
I know. Decent Price drop from when I bought them and also they give a bigger discount if you buy more. 5 of these gives you 24kw at 8200 ish priceTariff expires at the end of March when it becomes 12p and 36p, I will be moving to utlitita at that point on 5.33p.
