SolaX Triple Power Battery Balancing
spacemoc
Sep 28, 2024
Northamptonshire
There appears to be a lack of information available on how to properly balance SolaX batteries. Here are the steps:
  1. Force discharge the batteries down to 10%.
  2. Shut down the master battery and disconnect the slave battery.
  3. Short the master battery, then reconnect it to the inverter and power it back on. You should see a state of charge (SOC) on the inverter that is significantly higher than 10%.
  4. Discharge the master battery down to 10%.
  5. Once complete, reconnect the slave battery and return the system to normal operation.
At this stage, both batteries should be at the same SOC (10%).
However, there is one issue: the master battery will not operate without at least one slave. So, how does one balance the master and slave when only two batteries are available?
Question is what does it mean: short the master battery?
Shorting any battery is dangerous, so I'm not sure. It may well be worth a look for a YouTube video on how to do what you want to do.
I think your battery can be set for forced charge via the app, so basically it fully charged them from the grid, which is another way of balancing them out that I have used on other batteries.
