Quick question can you have an Rcd at both ends ie all garage or shed consumer units have a built in Rcd, now from off my head i don't have any Rcd on my house consumer unit. So once i take feed from the back of an interior 2 gang switched socket then hole to outside of house once that's sealed up i can run straight up the garden or first run into a weather proof outside box then run up garden. Weather proof unit with or without built in Rcd.
[SIZE=12pt]Choice 1. This is what i will be doing. Permanent power
A. Take feed from rear of interior 2g sw. Skt with 2.5 mm 2 core armoured cable on a 32 m run up the garden to shed.
B. connect to gland then connect live/ neutral to RCD 2 way consumer unit with 6amp/ 16 amp mcb's
C. Connect earth wire to earth rod/ clamp buried in garden - connect other end to brass tag on wire by consumer unit.
D. Run 2.5 mm TWE to 2g sw skts x 3 daisy chained.
E. run 1.5 mm TWE to light switch then to light fittings that are daisy chained.[/SIZE]
Am fully aware about Part p.
Code:
The reason why I'm going from the back of a socket in my back room is because I can't go straight from my house consumer unit as its under the stairs. Hence coming off the back of a none used socket. is this ok.
