Hi Guys,
First post here so bear with me on this one.
I've been looking at the 17 th edition dual rcd boards you can buy at the usual sheds and I can't help wondering if the main switch is underated if you use all the mcb's supplied. Heres my logic.
Both RCD's feed from the main switch outlet side.
They come with 4 x 32a, 2 x 16 amp, 3 X 6 amp, 1 x40 amp
Working with diversity for what i would consider a typical install
1st ring downstairs = 32A no diversity allowed
2nd ring upstairs = 40% of 32A=12.8A
3rd ring kitchen = 40% of 32A=12.8A
Assume 4th 32 amp breaker is for 12.5kw cooker= 10A+30% remainder =10A+13A = 23A total
3.5KW immersion @16A = 3500/230 = 15.2A no diversity
2nd 16 amp spare
1st lights D/strs @ 6A @ say 8 x 100W= 800/230=3.5Ax66% = 2.3A
2nd lights u/strs @6A say 6 x100W= 600/230=2.6Ax66%= 1.7A
3rd lights outside @ 6A say 2x500w=1000w/230=4.3x66%=2.9A
Shower @ 40A say 9.5kw=9500/230= 41A no diversity allowed
Add all these up and we get 143.7A potentially through the mainswitch rated @ 100A.
I know we can assume that not all the circuits will be loaded at the same time but it's nearly 50% over the main switch rating.
Am I missing something obvious?
Candleman
2nd 16 amp spare
Candleman
