Little room in cuboard for henley blocks so could i send the tails into a small intermediate cu, but wire the tails and house cu feed into the permanent live terminals and then the workshop off the switched side mcb?
If so, given that the switched contacts are not switching the house feed (as that is in the same terminal as the tails) would it also be acceptable to leave the 63a main switch in place rather than have more expense of replacing that for a 100a. After all it isn't switching 2 cu on the contacts, only one.
Danny
Danny
