johnb2713
Disconnect the wire from the timer terminal in the fan and see if the light issue is resolved.Brown is the live terminal and black is in the timer terminal
He definitely exists cos I saw him lol but probably not registered hence why he won't answer the phone or messagesthis is what you said I believe ? so therefore I can only assume either he doesn't exist or he is not registered or something similar but as I cannot know this from reading a forum post I used the word allegedly!.
Only you know the truth of this , is that OK as an explanation for you .
And from the connection in the light?Disconnect the wire from the timer terminal in the fan and see if the light issue is resolved.
Leave as is, just make sure the fan end isnt touching anything - insulate it or put a Wago connector / screw terminal on itAnd from the connection in the light?
Cheers ill have a look when I get indoors laterAnd from the connection in the light?
