- Nov 30, 2008
- 927
- 54
I thought the same but I think it's the grey from the 3c&EWhat is the white core in the neutral block?
Ah possibleI thought the same but I think it's the grey from the 3c&E
It is grey from the 3 coreWhat is the white core in the neutral block?
I dont see how thoughI agree with Sharpend. It sounds like the fan is incorrectly wired.
Which make of Fan?
Not on my at the momentHave you the instructions only I can’t seem to find that one online!
I havent disconnected the fan from the isolator, sorry this js all a bit new to me lol. what would that achieve if I do so? Because dosent it need an isolator switch?Some fans of the lesser known may not use ‘generic’ ‘standard’ connection connotations. The fact that you turn in the isolator and fan starts when it shouldn’t suggests something is wrong at fan. Have you disconnected the fan at isolator and tried lights?
The lights work correctly using the switch but the fan wont fire up, when the lights are off and I turn the fan isolator on the lights turn on but become dim and then the fan kicks in.By disconnecting it you will establish if your lights work correctly.
No it was just a fan the Mrs got onlineBizarre - but the forum won't let me quote the post showing the make of the fan - which I don't recall ever seeing this.
Did the "spark" source this?
So you either have a poor quality switch or a poor quality fan!The lights work correctly using the switch but the fan wont fire up, when the lights are off and I turn the fan isolator on the lights turn on but become dim and then the fan kicks in.
