Hi all,
A storage heater in the hall of the place i’ve just bought isn’t working.
it is a Dimplex SH12 439356 Series B.
In the electrical test, the electrician said power is going into the heater correctly. When I adjust the input/output dial i can hear clicks so possibly the thermostat is working?
I have set input to max and there is no heat coming out at all.
is there a way whether i could test ifit is a faulty thermostat, or whether it is something more serious, i.e will need replacing?
Thank you,
Martin.
PS how do you get photos small enough to attach on here?!
Thank you,
Martin.
