electrician786
- Jan 22, 2012
- 208
- 1
Thats exactly what it is.Can't remember the name BUT it looks like that carp that was out in the 70s. Used a lot in Council Properties. It was [ I think] a form of prewired conduit that you ordered in pre-cut lengths. Shucking frite if I recall correctly. I think it was made by Meta flex, could it have been called Meta-Cable?............I dunno, ranting now, will ask Monsieur Merlot............... :coat
No, but yes to the earlier two picsI've set a photo bucket account up, I hope this works.http://i1169.photobucket.com/albums/r503/electrician786/94f0e875.jpg
They came in pre cut lengths, each were numbered and labelled as to what they were for, many of the council houses were identical so you would get a delivery for about 5 at a time all the same. Then you just had to fight for your install team to get a full set before they all went.Yes it surely is a pain, I wonder how they ever got 100M of that on a cable drum. Especially the 10mm cable that I stripped out.
That was the stuff I thought he was talking about until the photo's went up.What was that pre wired conduit called ? Came in a plastic oval segregated conduit, you could never get 3 core and earth. used it once. Absolutely shucking fite, had to install it mid winter, fricking conduit snapped when you bent it
Not quite, we used it on Haden housing (subsiduary of Haden Young) in 78its like that other must use stuff,prewired conduit, it was so good the only people to use it was the council,
glad I only ever had to strip it out,!
Thank you, that will do nicely!Are we talking about Anaconda pre-made wiring systems for crappy new build houses and flats?
That's the s**t, never really made the impact they thought.Are we talking about Anaconda pre-made wiring systems for crappy new build houses and flats?
