sub main cert
I would do a cert for the sub and then a continuation sheet for the garage
My certificates have a line for supply or final circuit, so if its a supply cable its tested on the same certificate as the final circuits.
that is where you insert a D or F you still need the info for the oragin of supply
Yes very true, the eic I use lists all circuits (supply or final) and a separate pages or columns for origin and supply chatacteristics, plus any isolation between.
