no, they are not. you are not using them correctly...Submersible Pumps Are Flawed
Well I've been on construction sites for over 40 years and I've never seen a sign saying your welcome to use 230/240V tools on this site.240V equipment IS allowed on construction sites.
Under certain circumstances, as is 400V equipment.
I will not pass judgement on the pump as I don't have enough information, except to say that if the pump is being raised and lowered by the cable then that is incompetent &, that a carpenter should not be fault finding on faulty electrical pumping equipment.
This is not specifically the carpenters fault, and is a failing under MHSWR among other statute laws.
regardless of voltage, you should be giving the equipment a quick visual before using it anyway which should highlight the damaged cable, where it should then be taken out of service for repair.What happens when the cable becomes frayed?
Two things can happen.
1 - The user can be electrocuted
2 - Water can pass down the copper strands and inside the pump destroying it.
I've seen one of those happening!
Try putting that to HSE on site then, no hard hat, no Hi-Vis, no Steel toe caps, no 110V and its Good bye.there is no statutory law saying 230v cant be used. yes, 110v is recommended, but that does not make it illegal to use 230v
I have seen contractors thrown off site for not using 110V, I've even been on a site that was shut down because the main contractor had failed to provide 110V outlets around the site.
So where is it permitted, obviously to feed the 110V stations and cabins but where on site ?
I do not believe that you will have HSE present on many sites, especially now FFI have kicked in!Try putting that to HSE on site then, no hard hat, no Hi-Vis, no Steel toe caps, no 110V and its Good bye.
That's good because I like wearing trainers even though I'm an old git.It IS a recent change, please refer to BS7671 & BS7375, there are situations where it is allowable within H&S law, BS's, CoP's & ACoP's, whether the idiotic H&S officers & PC's for the sites are competent to manage this is a different question.
where did I say that?Prodave seems to think I think 110 volt cables don't snap. The point is when they do you are unlikely to get killed.
