Managing electrical risk during refurbishment work
A number of electrocutions involve workers who are not electricians
but who are carrying other works, such as plumbers and joiners. These
incidents could be reduced by:
- Understanding the system
Those responsible for planning and managing refurbishment work must
understand the electrical system of the building in which the work
takes place and liaise with the building occupier.
This will enable building work to be planned and managed so that
the integrity of the electrical system is not compromised and the
workforce remains safe.
- Working dead
Relevant parts of the electrical system should be isolated if the
refurbishment work, e.g. labouring, joinery, or plumbing, is liable to
disturb or damage the existing electrical system and expose people to
electrical danger.
- Portable electrical equipment
Tools, plugs and cables designed for DIY and domestic use are not
suitable for site conditions. You should use cordless tools or those
that operate from a 110V centre tapped to earth (CTE) supply system so
that the maximum voltage to earth does not exceed 55V.
Regularly inspect power tools and take them out of service if they
are damaged. Tools should be serviced by qualified electricians. Do not
do makeshift repairs.
- Residual current (trip) devices
Where mains voltage (230v) is used, the risk of injury is high if
equipment, tools, or leads are damaged or there is a fault. 230v
equipment should be visually checked for damage every shift, have a
visual inspection every week and have a combined inspection and test
before first use on a site and then every month - ideally records of
these checks should be kept. An RCD is a device which detects some, but
not all, faults in the electrical system and rapidly switches off the
supply.
RCDs must be properly installed and enclosed; checked daily;
treated with care; kept free of moisture and dirt; and protected against
vibration and mechanical damage.
- Lighting systems
Protect cabling and bulbs against breakage. If a bulb breaks, the
exposed filament may present a hazard. Have a system for checking bulbs
regularly to maintain electrical safety and to keep the site well-lit.
