I could, however I would have thought that any sensible electrician would know of the potential dangers.One potential danger has already been mentioned.Double pole switching would be safe as both live and neutral are disconnected to the final point of use.
We then have to consider the problem of dissipation with high voltage use,metal halide lighting would come to mind when this could pose a problem.
One of the main problems I would find when any circuit is switched via the neutral would be a, no electrician would expect this and assume the connection to supply to be nullified, b, any loss of earth on a pme or tncs supply would leave a potentially dangerous situation when undertaking any minor maintenance on any installation.
