- Mar 28, 2008
- 14,301
- 947
Look, you're comparing apples with pears.
Really? Two separate circuits to one unit..
e.g one double gang switch having TWO sources of power?
Regulation please may help?
Hi 64sp, I am sure this forum is leaving you more confused than when you started.Hi
I have bought a Megaflow 210dddd which is a direct model (electric heating only) with 4x 3kw immersion elements. It’s providing hot water to 2 showers in a swimming pool changing room and so I went with the 4 immersions so that I could get quick re-heat times when the showers are being hammered by the kids!
The electrician is coming next week to put the wiring in before the plumbers commission it. I could therefore do with some advice and thoughts about possible/best ways to switch the immersions so that I can have a more educated conversation with my electrician about what I want to achieve. In the past (other houses) I have only had either a single immersion (20amp DP switch to turn on and off) or in one case a top and bottom immersion with one of those bath/shower DP switches to choose between bottom OR top.
The consumer unit is close to the water tank and so it will be easy enough for the electrician to run whatever he needs to provide the initial supply (assume it will be a big old cable given the potential for 12kw / 52amps being pulled). I’ll leave that to him.
What I am interested in is whether anyone has experience of these 4 immersion versions and what switching options they have installed. The layout seems to be 1 immersion at the bottom, 2 either side of that slightly higher up the tank and then the 4th about half way up the tank. I’m not clear on what that layout says in terms of which ones should be used on their own or together.
I do want the potential to have all 4 on at the same time for maximum speed heat up, but equally want to be able to have 1 or 2 on when speed isn’t an issue and/or I just want some hot water for the sinks.
Any thoughts on how best to setup the switching?
Presumably one option is to have 4x 20amp DP switches and just switch each one separately in whatever combination I want (or all together) but should I have a more sophisticated method?
Any thoughts gratefully received!
Regulations are a guidance not laws, in the Regs themselves it's stated use common sense.Really? Two separate circuits to one unit..
I would set that up with 4 timers so that it's not running the immersions all the time, 24/7. Bottom immersion is your main unit, ideally that one would be on an off peak tariff. Top immersion probably won't do much for you, that would be just a booster for an individual bath should the tank be drawn down. Probably not even worth connecting? The 2 middle units would provide the extra boost for periods of high demand, so set those to run when you think high demands will occur. Modern tanks are very well insulated, which helps a lot, once heated they stay hot for over a day from what I've seen. I would also consider changing the shower heads for ones which mix air into the water and reduce the amount of water used - sounds like that could save you a small fortune.I think there is only 1 spare way in the CU. I was so focussed on how I would like the switching to work I hadn’t thought through how the electrician will get the power to the immersions. I guess I assumed a large amp breaker and a big cable that would daisy chain / split into the switches - but totally makes sense why you say 4 radials.
dont let him see those night storage heaters that require 2 different supplies, both on peak & off peak. he'll be calling the electric police about those
Or many hot water tanks …..
place i was at the other day has a hot water tank. 3 elements. all invidivual circuits. one on L1, another on L2 and 3rd on L3. surprisingly, it hasnt killed anyone yet
I think they use something similar to a "Belfast" immersion , the proper name escapes me, that's the colloquial term we used, it's a small tank attached to the main cylinder with the immersion heater element in it, so it basically heats the water as it's drawn out.Please excuse me for diverging from the original question.
Myself and Mrs sometimes stay in Premier Inns, which appear to be all electric. (I'm not saying they all are but definitely visited several). These hotels seem to be capable of providing everyone with morning showers or baths, probably all within a couple of hours, and without fail.
How are they equipped to do this? Anyone know?
indeed it could. As has been stated on here frequently MOST of us know very very little compared to a select ( self appointed ) few. Just look at the utter S.H.Y.T.E. that has been posted on various threads here recently. People stating how great they are but asking the most puerile questions. Stating stuff CANNOT be done but when asked to quote a Reg run off crying to nanny! Anyway, rant over. I thought it was me that "knew little of these things"! It must be contagiousThat could all be total bollicks tho, I know very little of such things
the recent sunshine hasn't made you any happier then?indeed it could. As has been stated on here frequently MOST of us know very very little compared to a select ( self appointed ) few. Just look at the utter S.H.Y.T.E. that has been posted on various threads here recently. People stating how great they are but asking the most puerile questions. Stating stuff CANNOT be done but when asked to quote a Reg run off crying to nanny! Anyway, rant over. I thought it was me that "knew little of these things"! It must be contagious
Oh how WRONG you are! You should have seen me when the weather was miserable! My fluffy cuddly kitten like persona was almost approaching terse and, how can I put it?, I was becoming a little grumpy! I know it's hard to believethe recent sunshine hasn't made you any happier then?
That's it,Thanks Steptoe. Your comment, plus a bit of Google has led me to a "Willis" heater, which broadly fits your description.
I'm still struggling to understand the thermo-dynamics of this but it's probably part of the answer.
I think it looks like having a stored hot water supply boosted by an instantaneous heater, but is that it ???
