Dal Roberts
Been to look at a job, the property is a 1st floor flat 3 bed , the service head is situated downstairs in communal external meter cupboard with 16mm tails (standard tails not PYRO 10mm which I have seen before) rising to the flats CU more than 3 metres away to board which is a BS3036 board, customer requires a 10.5kw supply for new shower, they don't want to spend out on a new board and the only way I would be able to offer install under section701 would be to henley block at the CU in flat itself and feed the existing BS3036 and fit alongside the BS3036 a shower CU 50amp with 30ma RCD, in this situation surely the tails would need to be upgraded to 25mm and the max of 3 metres rule would also apply, any suggestions would be appreciated
