personally I wouldnt bother, I think uni strut would be easier and look better.id go for armoured and a catenary wire if i was doing the job
depends on the length of run, unistrut would look terrible over 30ft. me i'd go with unistrut upto 1 length at most but probably not over 3m anything over that i'd go for a catenary wire and in both cases SWApersonally I wouldnt bother, I think uni strut would be easier and look better.can I ask the question,,,,?????? please.....
= 5mdepends on the length of run, unistrut would look terrible over 30ft. me i'd go with unistrut upto 1 length at most but probably not over 3m anything over that i'd go for a catenary wire and in both cases SWA infact i have done this exact thing recently at a council house, the run was about 30ft or so in length between buildings and went from the eaves of a 2 storey building to a single storey outhouse.
Cos thats your job Steps and no one really asked it much while you were AWOL.why hasnt anyone asked the all important earthing question.?OP, what sort of supply are you taking out to the garage?
I'm not actually going to do it, I was just curious to know how it was best done. Am I right in saying though the earth would come from the MET?= 5mwhy not longer?
I have done 10m runs in factories, and between buildings.
tho in all honesty, if its going to be anything over 5m or change of heights etc then I think burying it would be the only neat way of doing it.
bad day explodeSteps, while you were AWOL someone reported seeing your cart crossing Spaghetti Junction heading for the coast , with a load of topsoil on board. It was said that you were exporting earth.
it depends on what type of earthing system you have,I'm not actually going to do it, I was just curious to know how it was best done. Am I right in saying though the earth would come from the MET?
its not misleading, it is a fact.steptoe, your sig has been bugging me for a while now as i feel its quite misleading. while BS7671 in itself isn't a legal document the building regs are part of the law, in turn the building regs require you to follow BS7671 so whilst not a legal document in its own right it is required to be followed by a legal document and can be used against you in law so in a roundabout way is law.
the guy running our 17th edition update course told us they did it this way as any legal document needs to go though the house of commons to get changes approved and they felt that the electrical regulations needed to have changes/updates too frequently for this to be viable.
considering the 16th was around for how long???????
i don't know how true that last bit is but i believe the first part is close enough to the truth.
Not quite correct, Building Regs. do not require us to follow BS7671.steptoe, your sig has been bugging me for a while now as i feel its quite misleading. while BS7671 in itself isn't a legal document the building regs are part of the law, in turn the building regs require you to follow BS7671 so whilst not a legal document in its own right it is required to be followed by a legal document and can be used against you in law so in a roundabout way is law.
so when have you exported on tnc-s??it depends on what type of earthing system you have,if you have TN-S then it is fine to take an earth from the MET,
if you have TT then you don't usually take the earth out, you provide another spike for the garage outside
if its TNC-S you don't take it outside (never, in normal circumstances), you need to make your garage into a TT system and provide a separate spike for it on its own earthing system.
That is exactly what I was told whilst doing my 2391. Jsteptoe, your sig has been bugging me for a while now as i feel its quite misleading. while BS7671 in itself isn't a legal document the building regs are part of the law, in turn the building regs require you to follow BS7671 so whilst not a legal document in its own right it is required to be followed by a legal document and can be used against you in law so in a roundabout way is law.
this is the only reason i mentioned it as i was told its law in a round about way.That is exactly what I was told whilst doing my 2391. J
