NEVER,so when have you exported on tnc-s??
You have to wonder how culpable the DNO would be for running PME networks if something bad happened. How many other countries have PME networks?NEVER,but a few guys on here have argued that under certain circumstances then they would see no reason not to export it.
this is when the judgement of a competent person comes into play to take the responsibility of leaving (what in my opinion would be) an installation in a lethal condition.
Or indeed any other non-EU/EEA standard. The Building Regs. themselves require only that:There is no legal obstruction preventing anyone from using a standard from another EU country
I'd also been under the impression for some time that following IEE Regs. (now BS7671) had long been mandatory under the Scottish Building Regs., but I've not been able to find anything to support that. The handbooks appear to quote the requisite requirement of the Scottish Regs., which seems to be as vague as Part P:I was told on my 16th course, that BS7671 was not statutory in England and Wales, but that it was in Scotland.I've since been told by a Scot that it isn't?
I was not informed that BS 7671 is a law. I was told by my tutor during the 2391 course the reason why BS 7671 is not a law, which is what Bengie originally quoted. I am aware 7671 is non-stat, If I remember correctly it was the 1st question on my 2391 paper. JDisinformation everywhere. I suggest you guys who have been told that 7671 IS a law (or as good as) go back to your tutors who told you that and ask for proof. As mentioned a few times above, Part P only suggests using BS7671 to comply with the Building Regs but does not require it. Any other method can be used as long as it provides the same level of protection/security but you would need to prove that in a court rather than using 7671 as a defence.Remember 7671 is not a law but gravity is.
7671 is not law either directly or indirectly. What you agreed with was the statement that 7671 is as good as law which is not the case.I was not informed that BS 7671 is a law. I was told by my tutor during the 2391 course the reason why BS 7671 is not a law, which is what Bengie originally quoted. I am aware 7671 is non-stat, If I remember correctly it was the 1st question on my 2391 paper. J
It's the norm in the U.S., although unlike here the NEC requires an earth electrode bonded to the neutral at the service entrance to the building.How many other countries have PME networks?
I have not agreed with anything, I am just stating what I was told.7671 is not law either directly or indirectly. What you agreed with was the statement that 7671 is as good as law which is not the case.
So if you didn't agree which that when you were told it, did you question it?I have not agreed with anything, I am just stating what I was told.
I don't know that I would call it fault current. Perhaps diverted neutral current.So its just our implementation of PME thats crap then? That sounds much more sensible. Does the 'exported' earth have to be of sufficient size to carry the fault current at the head?
Well, to tell you the truth Ian, I did not question anthing my tutor told me. If he was wrong then he should not be in the position he is in. I was a 22 year old in a class of lads i'd never met before and did not want to look like a "wanabe" "mr-Know-it -all"So if you didn't agree which that when you were told it, did you question it?
Shame he rushed off to another lecture before I put my books back in me bag!!Good point. I can imagine what that would have been like. I think I may have approached him afterwards to 'clarify' it.
Why on a TNCS system would it not be acceptable to take the earth to the garage from the MET?it depends on what type of earthing system you have,if you have TN-S then it is fine to take an earth from the MET,
if you have TT then you don't usually take the earth out, you provide another spike for the garage outside
if its TNC-S you don't take it outside (never, in normal circumstances), you need to make your garage into a TT system and provide a separate spike for it on its own earthing system.
