Hi Steptoeit depends on what type of earthing system you have,if you have TN-S then it is fine to take an earth from the MET,
if you have TT then you don't usually take the earth out, you provide another spike for the garage outside
if its TNC-S you don't take it outside (never, in normal circumstances), you need to make your garage into a TT system and provide a separate spike for it on its own earthing system.
Where did you get this info - particularly on the TNC-S. i.e not taking the earth outside ? Guinness
