- Nov 19, 2010
- 241
- 0
I'll just stick to the hacksaw
Terminate swa to an adaptable box then take the conductors through into the cu (box is butted upto the cu), terminating to the mcb/met & neutral terminal & earth flylead from earth nut (dont bother with banjo's anymore) of gland to met. No need to join anything if its cut to the right lengths.Hi there Am a student lecky and was wondering did you wire the swa straight to the MCB with no connector block in an adaptable box?. And just checking, I'm using 4mm swa and I need to connect to a 32A mcb?
Thanks for the advice, helps alot.Terminate swa to an adaptable box then take the conductors through into the cu (box is butted upto the cu), terminating to the mcb/met & neutral terminal & earth flylead from earth nut (dont bother with banjo's anymore) of gland to met. No need to join anything if its cut to the right lengths.
Thanks for the advice!! GuinnessBest I can d at the moment...Submain to a DB that I TT'd, so cpc terminated to Earth nut in an insulated enclosure.
http://i83.photobucket.com/albums/j293/gazjothomas/DSC00798.jpg
If it was a normal final circuit the cpc (3rd core) would be taken to the met of the DB and an additional fly lead from the earth nut would be taken to the met also.
What an unusual uneducated statement!Tripe
