Testing 3 phase circuit
When testing and documenting a 3-Phase circuit, do you?
  • Write the results on one line per circuit showing the worst result of the 3 phases
    Votes: 5 50.0%
  • Write the results on 3 lines of the test cert, showing individual results of each phase. Somehow ind
    Votes: 4 40.0%
  • Make love to a sheep
    Votes: 0 0.0%
  • Something else (please comment below)
    Votes: 1 10.0%
  • Total voters
    10
I record all values, Ph>Ph, Ph>N, Ph>E, on my own docs for my records, and put the worst on the cert, that is the highest impedance and the highest fault current as appropriate.
you missed 'im a 5DW, i cant work with more than 1 live'
I cannot comment on 5DW due to my own career upbringing. Technically, I'm not even that. I am shamed to say, even though I have been in the game for over 10 years now, due to 'external restrictions' I don't have all my qualifications. Long story, but I'm not of apprentiship origin. :blush:
One thing I will say though, I certainly know a lot more than some of the ****e churned out by the likes of JTL. The amount of 'fully qualified', apprentice trained sparks I have come across that cannot do simple things such as 2-way lighting is discusting.
Ooops, off topic there a bit.......
Do the sheep require having a drink bought for them first?
Just a free glass of tap water...
Canoeboy said:
Is it not a 3 Line (or Live) circuit  :innocent
Whats a phase.......
When is a phase not a phase ?
It's a freakin' phase, and it's live!.
How else can we have a 3 phase supply if we don't have 3 phase conductors making it up!  ]:)
None of the above.
Use 3 lines of the test certificate filling in the worst of the results from the 3 phases on the first line.
Leaving the other 2 blank?
With some sort of indication that the results cover the 3 phase circuit as a whole.
Effectively the schedule of results is used to identify ways in the board, not circuits.
Easy cert shows it as a 3 phase MCB on a single line if you select the right button option.
Gets my OCD going that does!
I guess it just stems from the fact that that is the way the board is marked up so I have always made the test sheets follow the same layout. I don't think I have seen anyone else do it differently.
