OOOOOOH. Scared Big Big now!!!!!!You picking on my Mate? X( I have the Direct number for the "Don's Boys".![]()
See, that doesn't do anything if everything's off in his flat also. It often is, I htink, he's not there a lot. Or, more specifically, if maybe it's just one thing that's bleeding though and that one thing isn't on. I did turn everything off at my main fuse one night, turned the main fusebox off overnight, but of course the fact that the meter didn't (digitally) move doesn't prove anything as something could be in line before the fusebox. And as Matey upstairs says, if his heaters went off, overnight, and went on next day again, he probably wouldn't even notice because they're slow to respond either way.Switch everything off in your flat, record/observe the meter reading, check the meter the following day.Don
Red light flashing... that's how you tell if it's going fast or not, isn't it? When the techie guy came to install the check meter, he commented that the original meter seemed to be going fast. He couldn't have seen the display from where he was, he was bending down to get into the under-the-stairs cupboard. He said it slowed down as he was watching it, and he said this as he was bending down.Even if its proven that your electricity was being stolen by upstairs, its not B Gas problem. So get this sorted ASAP. Don't turn off your consumer unit to check usage , as this would also turn off anything upstairs is nicking. Just try switching off all your own bits and look at the meter for the disc spinning or red light flashing..Something does not sound correct here anyhow. The storage heaters electricity would be shown separately from the normal electric on your bill. It may say 'Day' or 'Normal' and 'Night' or 'off Peak' for the two rates on your bill.
Where are the meters and fusebox. Are they in your property or in a common area ?
If something is connected after the meter but before the fusebox..See, that doesn't do anything if everything's off in his flat also. It often is, I htink, he's not there a lot. Or, more specifically, if maybe it's just one thing that's bleeding though and that one thing isn't on. I did turn everything off at my main fuse one night, turned the main fusebox off overnight, but of course the fact that the meter didn't (digitally) move doesn't prove anything as something could be in line before the fusebox. And as Matey upstairs says, if his heaters went off, overnight, and went on next day again, he probably wouldn't even notice because they're slow to respond either way.BB
All perfectly ok..Ahem - all this clamp metering and so forth - is it legal for me to try this? Don't I need to be an electrician, legally speaking? I wonder at the advisability of tampering, or appearing to tamper, with what is already a suspect installation.Anyhoo, I'm getting the landlady to have a safety inspection from BG prior to getting a proper sparks in, see what we find. I've been talking to BG's Escalation people, who have access to more info than the front-line complaints people. They're at something of a loss to explain how I can be being charged what I am. I'm on the click energy tariff and I'm using 10 units a day regularly at the moment. I mean, do the mathThat's about a quid or so a day. I'll keep digging.
BB
I LIKE THIS MAN.If it was my flat i would turn off everything of my own and whack a 1000v megger across the installation a few times .
The BG man came today to read the meter. That's a good thing as I had the reading witnessed yesterday so it'll all tie in with the daily readings I've been giving BG. BB
