We`ve recently had a few pallets of TL inverters delivered
Now we`ve checked with the manufacturer; and they have internal type B RCDs fitted already, so we don`t have to worry about that - but the bonding issues are another matter.....
Looking at the DTI "bonding tree", we can see that TL inverters are advised to have 10mm bonding fitted to the frame, and either spiked (TN-C-S), or taken to MET (TN-S).
Here are the questions that arise:
1. What about TT?
2. How do you attach a copper cable to an aluminium frame, without beginning a chemical process of corrosion, due to dis-similar metals.
3. Following that, what do you actually use on the Alu? I`ve seen guys use BS951 clamps, but I`d be more tempted to use "radiator earth clips" - EZ Type Radiator Earth Clamp
4. Do you have an issue with effectively lifting the "general mass of earth" onto the roof of a house - and increasing the likelihood of a lightning strike.
5. Insurance and warranty issues. House insurance companies have apparently used a bonded frame as a reason to get out of paying up, as the EZ had been taken outside the property. Yet NOT fitting it could void the warranty on your PV kit, or leave you open to legal challenge if someone got a shock on your roof.
n.b. I`m only discussing arrays which are out of reach (i.e. on a roof, not ground mounted systems).
Thanks all
KME
1. What about TT?
Thanks all
KME
