S soulman Senior Member Joined May 17, 2010 Messages 334 Reaction score 0 Nov 7, 2012 #1 Hi, Dimplex xl model. comes on for one night then trips the thermal cutout. When the thermal cutout is reset will work again for one night then trip again. Any advice please.
ProDave Twatt ™ Supporting Member Joined Nov 28, 2009 Messages 14,729 Reaction score 903 Nov 7, 2012 #2 Yes. the normal thermostat that is supposed to shut it off when it reaches temperature must have stuck (welded contacts) Replace that and your problem should be solved.
S soulman Senior Member Joined May 17, 2010 Messages 334 Reaction score 0 Nov 7, 2012 #3 Cheers Dave, Thats great i shall check it on monday.
S soulman Senior Member Joined May 17, 2010 Messages 334 Reaction score 0 Dec 2, 2012 #4 Dave you were correct contacts welded shut, replaced all working . Cheers
a3 3 of 9 Joined Apr 17, 2009 Messages 2,458 Reaction score 0 Location Delta Quadrant Dec 2, 2012 #5 soulman said: Dave you were correct contacts welded shut, replaced all working . Cheers Click to expand... Thanks for stopping back and letting us know
