Thing's I don't like.
Hager CU's
Yep, never thought I would say that. Â the last one I installed was in my own new house just before Amd 3, it was an "old" one with a metal back and a plastic front. It was brilliant. A continuous row of round 20mm knock outs all along the top and bottom plus a few larger ones. Perfect for terminating SWA cable direct into the CU, and for ordinary cables there's nothing wrong with a round hole and a grommet. So yes I USED to like Hager CU's.
Yesterday I installed a new Amd 3 Hager CU, the first one I have seen. Â Oh my god, this is a lesson in how to take a good product and ruin it.
Gone are all the round knock outs, so when I come to install a couple of SWA cables I will have to terminate them in an adaptable box.
In the bottom of the CU there are only 5 small rectangular knock outs. By the time you have farted around with the silly bit of grommet strip, there is just, and I mean only just, enough room to get two 25mm tails and a 16mm earth through one. Â The top has a row of much larger knock outs, but why do you want much larger on the top when IP ratings will be an issue if you use them?
As I say a perfect example of "it ain't broke, so we will fix it and ruin it"
All the "old" one wanted was a metal front with no changes to the back part of the box, but of course that would have been far to simple.
Â
