This afternoon`s job "on the way home"
kme
Fridge Keyholder™
Mar 7, 2008
9,984
In the office again.
You know the score......a customer`s parent or relative asks you to call in and change a light fitting or 2 in their lounge. You think - sure, I`ll do that on me way home......
So, this afternoon, I arrived at Mr. & Mrs. bloggs` house (not their real name). They`ve bought 2 ceiling lights, and a matching wall light, to replace the existing.
Take down existing lights - twisted pair coming out of ceiling. Draw it down - connector block, then more twisted pair, then stuck! Other ceiling fitting similar.
Soooooooooo, we go upstairs, move furniture, pull back carpets and lift board - to find original ceiling rose (minus cover) under floor, with twisted pair flex.
"No problem", says I, "we`ll fish it up, re-connect, and drop some proper flex down for connection."
Fished up - two core (no cpc) : headbang (new fittings are class 1)
Go down stairs again, and drop wall light off to check cable (recent addition (<5 years).
Its wired with 4 core ALARM cable, FCOL!!!!!
CU has been done at some point (TN-S, front end ELCB, CU with main switch & 13 ccts. Lights on 3 different ccts, 6A,6A and 20A (all 1.0mm).
Guess who`s having a partial rewire (don`t want walls chased, and don`t want trunking).
headbangheadbangheadbang:innocent
You know the score......a customer`s parent or relative asks you to call in and change a light fitting or 2 in their lounge. You think - sure, I`ll do that on me way home......So, this afternoon, I arrived at Mr. & Mrs. bloggs` house (not their real name). They`ve bought 2 ceiling lights, and a matching wall light, to replace the existing.
So they don't want the lights then??
I could get you some nice candle brackets!
Multipurpose!... they can have light whilst praying that they don't either burn the house down or electrocute themselves;)
ROTFWL
Thanks guys - haven`t laughed so hard in quite some time.
The plan (not perfect, but a damn sight better than current) is to replace the main lighting supply cables, but leave the switch drops (all switches class 2 - platescrews not electrically connected to back boxes).
Oh, and use all 4 of the alarm cores, so providing double the CSA to the wall light - which only has a single 40W lamp in it anyway........... ]:)
Rip out the Voleb, and somehow provide split RCD protection instead.
Gonna be costly, though ]:) ] :) :popcorn
(n.b.) no galv around, but (honestly) the customer DID ask if I could earth his new class 1 fittings to the copper pipework under the floorheadbang:red card
KME
KME
of course you cant take it to the pipe. i though everyone knew you could earth it by putting some soil in the void next to the light and an earth wire into that
Thanks guys - haven`t laughed so hard in quite some time.The plan (not perfect, but a damn sight better than current) is to replace the main lighting supply cables, but leave the switch drops (all switches class 2 - platescrews not electrically connected to back boxes).
KME
Hi KME. Did I read that right ,are you proposing modifying a 240volt circuit, in the knowledge its wired in Alarm cable :eek:
You mean:
??That bit??
Can`t think of a good reason why not.........
No, it`s no good. I can`t do this anymore. I lied, mate - I can`t double up on the alarm cores, or I wouldn`t have an earth. Stupid sods should`ve put 6 core in, at least!!!!
The customer knows that the wall light has to have new cable A1 - My flippant attempt at a joke mustn`t have worked. ;)
You mean:??
That bit??
to be fair kme, i knew by your standard of working that you were joking, youd have out a 12 core alarm cable in in the first place :^O :^O
You mean:??
That bit??
Hmmmmm . Cant say there was any indication that you meant it as a joke , but I will not question your integrity or the competance of a fellow forum member........Couldnt come to lower myself to do it KME ...just not my style mate ;)
