I have several Europa RCD to install they are three phase 415v. They are being connected to a three phase supply that has no neutral. We cannot get the test button to operate when pressed. When you hold test button it is putting a resistance of 3.28K ohm between the neutral connector and L2. What step should I take to get operation from the test button?
Cheers Adam
Cheers Adam
