Timer
Stevie h
Oct 18, 2008
291
Liverpool
Hi Lads , I am after a 24/7 230v timer that will do timed segments of less than 1 min .. any ideas
Cheers
Ste
What? you want the ON (or OFF) period to be less than 1 minute??
I've never come across anything that can do this apart from a PLC....
whats the application?? someone might have an alternative idea
Hi Noz , its for a sounder in a factory to tell the lads when break is over , home time etc , they have the sounder and asked me if there was anyway to link a timer to it, but the sounder going off for 1 minute will be to long ........
Ste
---------- Post Auto-Merged at 19:48 ---------- Previous post was made at 19:47 ----------
Cheers Andy
Contactor with off delay timer, like a Y/D starter?
Push button or other impulse to start, timer times out and turns off?
Probably needs a bit of refinement before implementation?
PLC would probably be the best way to go
or you can use another timer which will only output for a few seconds. ive done this a while back to a door sounder. DIY PCB kit, but only takes 5 mins to solder
EDIT: kit similar to post above
Thinking about this, you could probably do this with a combination of the above or perhaps even something like a Siemens Logo device.
Beauty of PLC/Logo is built in RTC.
I have used the siemens logo to replace 6 timers that were forever being damaged by Mr nobody.
The logo unit was cheaper than 6 timers
Demo software can be upload from here
Please open attached thumbnail below
Thinking about this, you could probably do this with a combination of the above or perhaps even something like a Siemens Logo device.Beauty of PLC/Logo is built in RTC.
Can recommened the Siemans Logo,Used these a lot for various timing situations when i was in maint at previous place.
---------- Post Auto-Merged at 22:43 ---------- Previous post was made at 22:41 ----------
There are numerous manufactures of time & attendance control systems including bell sounders etc..Something like this probably quicker than builder a bespoke timer..
no need to re-invent the wheel as they say...
Break Time Systems and Sounders Bells - UK Time Solutions
Guinness
Nice find Specs Loc
