- Nov 28, 2009
- 14,670
- 827
Yes I don't mind being described as Plain, Simple and Succint :innocent .Dave, thats a real good explanation,plain, simple, and succint,
Sorry, I don't think I got that bit :Salso goes a good way to explaining what happens under conditions of NO fault and exporting the earth.
yes. depends on many factors. 400 would be worst case, but in reality it would probably be less.To earth?
yesDo they use concentric for 3 phase? (i.e 3 inner phase cores and one outer neutral core)If so I've not seen it.
Would that be due to any imbalanced currents in the local 3 phase system travelling down the shared earth/neutral?taking a TNCS out of the EZ and to the general mass of earth can actually produce a potential difference between the artificial (DNO supplied) earth and true earth, which you will now be standing on.
no,Would that be due to any imbalanced currents in the local 3 phase system travelling down the shared earth/neutral?
tell me what experiment you want done and if i can, i willno,even on single phase the DNO earth on TNCS may be at a signifigantly different potential to the true mass of earth,
remember the horse that got electrocuted at the race course a while back?
similar issue but a bit more complicated due to it being a quadraped with a bigger stride than a normal human and the stride taking the current across its heart,
you can prove it to yourself, but im not going to explain it to you as it could end up getting stupidly dangerous,
let ANDY do the stoopid experiments!!!
Haha, I don't intend to electrocute myself anytime soon!you can prove it to yourself, but im not going to explain it to you as it could end up getting stupidly dangerous,let ANDY do the stoopid experiments!!!
yes, you canYou're not going to get 400 volts neutral to earth by losing the supply neutral on a three phase supply.400 volts occurs between lines because they are out of phase with each other.
whilst there is often reported power failures (especially larger ones), i dont think any of the DNO publish what the actual fault was, wether broken L or N3) Someones electric not working, due to losing the supply neutral.
4) Any report on loss of supply neutral.
err, well lets ask the DNO if they permit it then shall we.this seems to be a common statement by a lot of the 'you can't run a TN-C-S earth to an outbuilding' brigade.
