Just yours mate!! Only kidding there must be many up to date boards with many crimped connections in them. I picked up a couple of packs of reds and blues while I was at my local Denmans the other day.Do you lot find that when upgrading from one of these boards yOu have to extend quite a few cables ? And the board is a mass of crimps sometimes? Or is it just mine lol
And they always fall off although I suppose board should be switched off with lid open exposed connections and all.The on/off lable is a bit wonky:innocent
i did switch it off... removed cover, switched back on and put fuse back in for lights & alarm....And they always fall off although I suppose board should be switched off with lid open exposed connections and all.
there was enough slack on the neutral to re-terminate into board to get it working again. i also quoted for a new CU at a later dateWhat did you do in the end Andy. board upgrade ?
