PC Electrics
That torch should be bright enough to land the shuttle at that price.This is the torch I usehttp://www.thetorchsite.co.uk/LED_Lenser_H7R_Rechargeable_Head_Torch.html
I use:
http://www.screwfix.com/app/sfd/cat/products.jsp?id=62191&ts=52409
fitted with duracell batteries (I have found they last the best).
It's very good and gives plenty of light both within working range and over 3 to 4 metres for moving around a loft. I also find I can get my bump cap (http://www.screwfix.com/prods/31899/Workwear-PPE/Protective-Clothing/Head-Protection/JSP-Hardcap-A1-Navy-Bump-Cap) on over it. It's also not so expensive that if you lose or break it you'll be crying into your beer.
I also use one of these:
http://www.screwfix.com/prods/35653/Power-Tools/Batteries-Chargers/Ryobi-One-CFP-180FM-18V-Fluorescent-Light-Bare
Back to the OP: if you're using your own torch instead of whatever you've been provided, then buy your own batteries.
If you haven't been provided with suitable light for loft or other work, then you should be, so ask for some.
