yum right ah kid but trying to find CCC for flex is non existantIts more to do with the type of insulation .
try table 4F3A for ccc and 3B for voltage dropyum right ah kid but trying to find CCC for flex is non existant
Not sure what you're getting at, that's the correct table for flexes.looked there PC but thats very limited as the specs for flex is very varied
there are many specs of flex so how can it apply to all?Not sure what you're getting at, that's the correct table for flexes.For flexes greater than 4mm use table 4F1A
for flexibilityso if tri-rated (single core cable) is all to do with the insulation properties why is the core fine stranded?as this is the first thing you notice when working with it then you have a gaze at CCC table for tri-rated and wrongly presume its due to the fine stranding
yeah obviously but just seems to be the most significant change where as the tri-rated pvc properties being able to handle more heat are not available in standard strand configurationfor flexibility
