Hi All,
      l have removed my cooker switch as l need to blank that off as l dont use it and it is too close to my cooker.l have the cooker plugged in behind .l was going to remove the cooker fuse from fusebox and leave the wires taped up behind the blanking plate but if l do this,the socket behind the cooker has no power.lf l were to connect the 2 blue wires with a connector block and same with the brown 2 wires,would this just result in a big bang or would it cure my problem? Also,there is a space on the back of the blanking plate for one of the earth wires...what do l do with the other one.Any help much appreciated
