16mm g/y only required if the cable is to be burried. If earth box is above ground then use 4mm. See page 29 OSG!
Lets not pull figures out of anywhere, Table 54.1 are minimum sizes for buried earthing conductors.
2.5 and 4 mm are minimum sizes which are relevent to reg 543.1.1 (iii), (iv), (v).
reg 543.1.1 requires us two use two methods,
The adiabatic, or table54.7
If the installation is tt how are you going to calculate using the adiabatic?
So more than likely we will need to use table 54.7 to size the earthing conductor.
What method are you using to calculate the circuit cpcs for compliance?
regards chris
