Just kyboshed that mate, it is now gonna be a big booklet I think!!!
That is quite possible, bearing in mind that when you Zs test you have all the parallel paths in place.What i have found is that books including the part p doctor book, do not discuss the hassles you have to get round sometimes when testing for say r1 + r2 and insulation testing when rcds and rcbos are involved.Another thing is i love to find other peoples test certs and have a look through them. It is surprising just how many electricians do not have a clue how to do a test cert.
What i often see are;
R1+R2 readings higher than the Zs
+1. very easy to get a Zs lower than R1R2That is quite possible, bearing in mind that when you Zs test you have all the parallel paths in place.
Stop talking rubbish.........It seems to be a stock answer for anything even slightly technical..........parallel paths indeed ???That is quite possible, bearing in mind that when you Zs test you have all the parallel paths in place.
You are the one doing the periodic........The chart/diagrams should be there before you write them.A chart can be your schedule of circuit results.AndyGuinness
What is the issue in obtaining r1 & r2 when an RCBO or RCD is involved.testing for say r1 + r2 and insulation testing when rcds and rcbos are involved.
