you have just been given 2 examples of where it would be fixed to the surfaceI think it should not be of length to warrant a fixing?tb ryan
ditto!What is the current carrying capacity of 2.5 t+e flat cable clipped direct to a brick surface?I don't have my regs can someone look it up tb ryan
Not only is this 'common sense', but there is actually a reg for this. It came in for the 17th, probably because of all those tankstats that are wired with 3 core using the cpc as the satisfied return!! (todays lesson from PC: use 4 core for tank stats)never use cpc as a phase conductor then
