- Mar 28, 2008
- 14,661
- 1,363
"IP44"
"Object size protected against" >1mm
"Splashing water Water splashing against the enclosure from any direction shall have no harmful effect. Test duration: 5 minutes
Water volume: 10 litres per minute
Pressure: 80–100 kPa"
So to be IP44 it has to have no holes >1mm diameter
And be able to withstand SPLASHING water for 5 minutes.
That does NOT IMHO make it suitable for outside use in constant rain for hours on end.
IMHO outside stuff should be IP65 or greater.
Interesting points Dave...
but not sure I agree with the logic of the test duration relevance....
If following the logic of the must withstand 5 mins splashing argument...
then as IPX5 also only needs to withstand a 3 minute test..
that also would be no good for 24hrs in rain...
The pivotal point is the source of the water, not specifically the test duration to verify compliance....
i.e..
Rain by most general definitions is not ….
i) Water projected by a nozzle (6.3 mm) against enclosure from any direction.. {IPX5}
[test duration at least 3 mins]
nor is it..
ii) Water projected in powerful jets (12.5 mm nozzle) against the enclosure from any direction... {IPX6}
It is some form of dripping or falling water splashes…
e.g.
IPX1 Dripping water (vertically falling drops) shall have no harmful effect.
[Water equivalent to 1 mm rainfall per minute]
or
IPX2 Vertically dripping water shall have no harmful effect when the enclosure is tilted at an angle up to 15° from its normal position.
[Water equivalent to 3 mm rainfall per minute]
or
IPX3 Water falling as a spray at any angle up to 60° from the vertical shall have no harmful effect.
[Water volume: 0.7 litres per minute]
or
IPX4 Water splashing against the enclosure from any direction shall have no harmful effect.
[Water volume: 10 litres per minute]
10 litres per minute is a reasonable amount of rain to be falling on your enclosure
Again as a general rule the water jets rating are more specifically for environments where walls / fittings are washed down with hoses….
Otherwise, if the IPX5 & 6 are intended to define rain fall..
Then on the table we go straight from rain fall to immersion at a depth of 1m!
IPX4 should be adequate for most rain environments, obviously prevailing winds and the physical mounting direction can have adverse effects…
As we all know that the average roof on most houses manages to keep most rain out with just a few overlapping tiles…
Then of course if you choose to fire a high pressure hose against any aperture water will get through!
http://en.wikipedia.org/wiki/IP_Code
Guinness
