I am hoping to use my own house for my assessment to join either ELECSA and intend to replace the BS3036 fuse board with a dual RCD 10 way CU. I have run some tests today and found that the only earthing I currently have is on the incoming gas pipe. ie no earthing...nice challenge for my 1st job!!!
I understand that I need to install an earth rod but have very little garden that is not covered in concrete, the only place I can install one would require to run around 25mtrs of cable to reach the CU. I have read the on site guide which recommends 16mm cable when using 25mm tails, but have also read that the cable can be a minimum of 4mm for a TT system
Most people have given me the stock answer of 16mm as the Tails are 25mm however I do not believe that this has to apply to a TT system although I am happy to be proven wrong. Considering the length of the cable needed would I best to stick with a 16mm or use something smaller?
My other question relates to the 10 way CU. I have read that TT systems require a 100mA time delayed RCD as the main switch with a 30mA RCD for circuits that require additional protection (bathroom, socket outlets etc). However, I intend to protect all the circuits with a 30mA RCD as none of my cables are installed in walls at more that 50mm or in earthed metallic covering. On this basis, could I use a standard 10way dual 30mA RCD consumer unit or is it a requirement for TT systems to have the 100mA time delayed RCD?
Ps: I have used the adibiatic equation for the earth cable but the calcs came out as 0.028 (based on a 9amp PFC), I am no expert on these equations but it does not seem right!!
Apologies for the essay but can anybody advise?
Many thanks
Many thanks
