i use a megger 1552. same as many others on here. and then others use fluke. or metrel. or others.hi people,what is the best tester to get to do the tests required for an average domestic install?what are the minimum required tests you have to do for a new / small domestic install?
As above mft1552 for
Hello Buddha. On your second question. If you care to give a list of the Tests you think are required then help will followhi people,what is the best tester to get to do the tests required for an average domestic install?what are the minimum required tests you have to do for a new / small domestic install?
How do you find the low current loop tests?AVO CM500 "all in one" for me, the dial is even set up as a mind jogger on the sequence of tests
thanks mate i will get my cock-eyed list together and see if you can help,i will put it on this thread and maybe pm you it.the megger 1552 seems to be the most popular with you guys,where is the best place to buy one,the megger in screwfix is 970 quid!!Hello Buddha. On your second question. If you care to give a list of the Tests you think are required then help will follow
if your useing the 1552 on your course then i would buy one, olci use 1552, they are a good tester and i got mine from isswww with the lead. about
dont start cpr untill i have been disconnected from the mainsray:good luck: :good night:Nothing at all wrong with that...So long as they know what to do if you do get a shock, whack you with a big stick if you're connected, then all's ok!!
The low loop tests can be quite predictable Batty as I believe the meter calculates the readings somehow based on a 230 or 240 volt supply!How do you find the low current loop tests?
