bladerunnerpv
Hi all, I've been reading this forum with interest for some while now, gradually trying to get my head around various topics from the discussions, and doing a fair bit of web searching to try and learn as much as I can.
I haven't seen a thread on my particular question, and am looking for some advice, so here goes. I have no practical electrics experience so apologies if I'm slower on the uptake. Obviously as a beginner I don't appreciate what's inadvisable or maybe even completely stupid ;-)
Background :
House with basically an East-West aspect, roof ridgeline is 170deg magnetic on a compass, so 10deg East of South, making one roof face 080deg the other 260deg, or w.r.t. South -100, +80 . I'll just refer to them as East-facing and West-facing for simplicity. Roof pitch is about 30deg.
What would I like it to do :
1 Use less grid elec to save me some money with prices being uncertain to say the least !
2 provide some level of EPS/UPS
i. to gas boiler so it doesn't get cut off in the winter
ii. for some medical equipment used overnight all year round
iii. provide enough for a fridge freezer and a freezer during power cuts, the fridge-freezer is more important
iv. to power wi-fi router which is presumably necessary to continue managing the PV system (mobile networks will go dead in a power cut)
3 potentially provide some hot water
4 down the line provide some electric vehicle charging, but that's prob. at least 2yrs away, maybe 5yrs
I've been doing some example builds using a free online system planner, which helps cost a system (at wholesale prices, parts only). It provides whole year graphs of split between PV, battery and grid usage, and can show a day's usage, so I can appreciate winter output will be limited, but would like to get as much out of the system as I can.
This led me to think that (ignoring cost for now) maxing out the panels is the way to go.
So I reckon :-
For a 390W Qcells panel
- the East roof will take at least 10 panels, possibly 11, depending on panel size and any fitting restrictions - there's a velux and a soil stack vent about at about 2/3rds way across the roof width, with a gap of about 1.5m
6 in a block of 2 rows x 3 columns and another block of 4 in 2rows x 2 columns,
- the West roof will take an upper row of 7 panels and a lower row of 4 panels
So for 390W panels that's a peak of:
East side 3900W or 4290W
West side 4290W
East+West 390Watts = 8190 to 8580W
If I go for slightly smaller dimensioned 345W panels I get
East side 10-12 x 11x345 = 3450 to 4140W
West side 11x345 = 3795W
East+West 345Watts = 7245 to 7935W
Light path:
The East side has some wintertime obscuration/shading due to nearby rooflines, first thing in the morning in midwinter there's an unobscured light path to the east, then sun goes behind nearby rooflines then iirc rises over them again later in the morning. My guess is that the top row of panels will get light before the bottom row in deep midwinter when sun rise back over roofline. Summertime is fine.
West side is OK I think
Kit: Ideally I'd prefer to go with british / european / south korean / australian / american
Battery : ~10kW ?
Questions I hope someone can help with please
1) What type of inverter, and what impact does it have on battery storage
1a) For the inverter I'm not sure if I need in 3phase or 1 phase and how does this relate to the PV output to the inverter?
It appears (to me) that for hybrid inverters 1phase inverters go to about 5 or 6 kW, so in summer a potential 8.5kw PV input makes it look underspecified and if it's stuck in hot loft my instinct smells problems, 3 phase inverters go a lot higher.
e.g. GivEnergy HY-5
Input Data
Number of MPPT 2
V range of MPPT 150 - 550V
Max DC input power 6500W [inadequate ??]
Max Input current 11A
Max PV voltage 600V
Nominal voltage 360V
Start up voltage 150V
e.g. Growatt MIN 6000 TL-X Dual MPPT Single Phase
DC attributes
Number of MPPT 2
V range of MPPT 80 - 500V
Max power 8100W [just adequate ??]
Max Isc current 16.9A
Max voltage 550V
Start up voltage 100V
e.g.
Soltaro All-In-One 5kW Hybrid, this claims some EPS backup
DC attributes
Number of MPPT 2
V range of MPPT 125 - 500V
Max power 7500W [just adequate / inadequate ?]
Max current 15A
Max voltage 600V
Start up voltage 125V
Three phase inverters look (to me) to start from about 3kW and go up and up and up
I picked a 10kW Fronius one to look at, they obviously make smaller ones too
DC attributes
Number of MPPT 2
V range of MPPT 270 - 800V
Max power 15000W [Looks way too high?]
Max Isc current 40.5/24.8A
Max voltage 1000V
Start up voltage 200V [Looks much higher - is this a problem for East roof in winter?]
Or this Growatt MOD 6000 TL3-X
DC attributes
Number of MPPT 2
V range of MPPT 140 - 1000V
Max power 9000W [Looks about right ?]
Max Isc current 16A
Max voltage 1100V
Start up voltage 160V
1b) Can a 3phase inverter only be used with an AC coupled system ?
(I'm not clear in my mind about AC and DC coupled systems, I've seen this https://www.deegesolar.co.uk/ac_coupling_vs_dc_coupling_solar_battery_storage/ which explains it at top level but ...)
1c) How is a 3phase inverter linked to a battery storage - don't batteries need DC input ?
Would I need a 3phase hybrid system like this
Giv-3P-Hy6
but appears to be commercial use?
Is this AC coupled only ?
And if I read correctly the backup power output is 3phase AC...
I think my house is single phase supply by looking at this
https://www.ukpowernetworks.co.uk/h...ngle-phase-and-three-phase-electricity-supply
Sorry I'm a bit confused here as you might have guessed by now!
2) Does the startup voltage on the inverter matter during winter - is lower startup volts better when less energy being produced? So is an inverter with a lower startup voltage more useful in winter as it will not waste so much incoming energy supply battery/house more kWh overall?
Or does the Max Power Point Tracker on the panel (inverter?) manage it all by balancing volts and amps in W = V x A equation?
3) Should I be looking at microinverters for the East facing roof ?
4) EV charging
5a) Can the solar system provide enough electric for the house and car, even in summer ?
Estimating tool suggests 6838 kWh Annual solar generation for a Soltaro All-In-One 5kW Hybrid based system
Our annual usage is ~4000-4200 kWh, so 2400kWh spare p.a, ~6.6kWh/day
but presumably the bulk of generation is Apr-Sep ? So would end up relying on grid for EV charging Oct-Mar
5b) is 7kW EV charger tech going to change over the next 10yrs, if I pay out for a PV system now is it going to be obsolete in 10-15yrs time ?
I speed read this https://www.smarthomecharge.co.uk/guides/22kw-three-phase-charging-is-it-worth-it/
which indicates 7kW is the usual way for home chargers and any faster requires 3phase home supply which is expensive to do - it quotes £3k+
5c) Should I be considering changing to a 3phase supply for EV? In which case a 3phase inverter is essential ? Although household will presumably run on 1phase of the 3ph available ?
Thanks very much to anyone who takes a look and responds helpfuly
Background :
So I reckon :-
West side 4290W
Light path:
Battery : ~10kW ?
e.g. GivEnergy HY-5
Input Data
Number of MPPT 2
Max PV voltage 600V
DC attributes
Number of MPPT 2
Max voltage 550V
e.g.
DC attributes
Number of MPPT 2
Max current 15A
Max voltage 600V
DC attributes
Number of MPPT 2
Max voltage 1000V
DC attributes
Number of MPPT 2
Max Isc current 16A
Max voltage 1100V
Giv-3P-Hy6
4) EV charging
