Why a drop in monies
Aug 5, 2014
8,988
1,517
Woking
I could write on the back of a stamp what I know about PV and could do with some help...
One of our friends (recently divorced so hasn't really dealt with this before) has noticed that the payment from the supplier is much less than last summer. Given that we have had a decent amount of sun this year she is concerned about the drop.
So what do I know?
The inverter is a sunny-boy
Their package was bought outright - a long time ago
Sorry if that isn't that helpful
Over to you....
some more details on the system would be useful along with any pictures you can get. As paddler said, if there is a fault with the inverter it should show on the screen as an error message. The other possibilty is filthy panels. Depending on the roof pitch, and location close to trees, flight paths of birds, panles can get really dirty during the drier summer months with subsequent drop in performance.  A wet summer can be better for output than a dry one oddly enough.
Canoeboy said:
 i had one where the builders next door to a house with PV made enough vibration through building work over a month, the DC plug worked out and full onto the floor)
I fitted a system next to the hotel that inspired Faulty Towers. This has now been demolished to build flats. The builders have been pile driving for months and it seems the system has failed, so it will be very interesting to see what has happened to the system.
Ok. Managed to get some more information:
 12 panels, size 3, Monocrystalline Sharp 240's
inverter type :string
cleaned about 2 months ago
Readings for last 18 months:
Feb-15 7678 7921 gives 243
Jun-15 7921 8867 gives 946
Sep-15 8867 9840 gives 973
Dec-15 9840 10252 gives 412
Mar-16 10252 10377 gives 125
Jun-16 10377 10816 gives 439 so a drop of 507 compared to same quarter last year
Sep-1610816 11263 gives 447 so a drop if 526 ditto
Does this help.
Thanks for your ideas and input so far....
Interestingly enough my loft is a lot cooler now that I have solar due to the panels totally covering my south facing roof.
have had one fault in my system, 6 months ago, was a corroded crimp on the roof, causing numerous shutdowns of the inverter.
I just checked the feed in tariffs for last sept and this sept and they are in line with the drop you are getting. From here  https://www.ofgem.gov.uk/environmental-programmes/fit/fit-tariff-rates
this sep-last sep in screen below
I might be wrong though as I have literally no idea about any of this.
Edit; wait, I thought the figures quoted earlier were pounds sterling not KW, think I have made a mistake again.
good investigation work there @Rob_the_rich but those figures are for new sign ups ;)
Once you are registered for FiT's you stay on the rate you signed up at.
Ok guys got some more information:
MCS Certificated Product Name: NU-R240J5
MCS Certificated Product Manufacturer: Sharp Electronics (UK) Ltd
MCS Certificated Product Number: MCS PV0007/37
Technology Type: SOLAR PHOTOVOLTAIC
Estimated Annual Generation (kWh): 2293.00
Declared Net Capacity (kW): 2.88
The install was one of the first (at the highest rate)
Not been to her house yet - wanted to get a few pointers first.
Many thanks for all the input so far guys
check the inverter display for error codes and panles for cleanliness, if yor friend is on the higher tariff then it was fitted a few years ago, and of the panels haven't been cleaned then dirt can build up. Pictures of the array would be good.
