Dan Martin
- Jan 17, 2012
- 16
- 0
Am guessing your thinking of an old PILC supply into a property where a modern cutout has been fitted to it?
give me a quote on that please?Then that building with the transformer is using the transformers TME as its termination into the premises, that switchgear will have a cable run to earth providing the PME. Btw TNC-s stands for Terra Neutral Combined - Seperate (Earth Neutral combined, separated at termination) For earth and neutral to be combined it HAS to be pme under ESQCR. If not either separate earth conductor or provide your own via TT
if there is only 1 rod, then it cannot be PME due to the lack of the multiple partThen that building with the transformer is using the transformers TME as its termination into the premises, that switchgear will have a cable run to earth providing the PME. Btw TNC-s stands for Terra Neutral Combined - Seperate (Earth Neutral combined, separated at termination) For earth and neutral to be combined it HAS to be pme under ESQCR. If not either separate earth conductor or provide your own via TT
my bad, its shallgive me a quote on that please?the other fact to be borne on mind is that even though it is labelled as PME do you actually test it to prove this fact?
your missing the point, unless there are 2 or more rods it cannot be PME regardless of what other links you addIf it is an industrial supply then the CT cabinet will have a line to earth connected to the neutral and to earth. Hey presto, PME'd
Each joint where the two are bonded an earth tail is sent out into the groundIf all thats happening is the N+E are being bonded together every so often i fail to see how that can be called PME as no Earthing as such is taking place.
and that is the problem, its not always done.Have heard of pnb but dont have much dealing wih is as I work U/G, its where the N/E is provided from a point away from the transformer and the premises? Will hold my hands up if that can be classed as tnc-s. But have always been told that for an installation to be given tnc-s it has to be pme.Am in agreement that there needs to be multiple earths. Direct supply from tx would have one at the tx and one at termination. But thats on industrial supply.
Thats true, I cant vouch for other peoples joints so in theory there could be no earth connected to any joints.
Only quoted esqcr as it was pretty definitive on when neutral and earth are combined there shall should be multiple earthing.
it looks as bad as the person that installed it,People keep going on about metal services coming into houses, well where's all that Yellow and Blue stuff going then, even older places have a black water pipe, I cannot remember seeing metal services for years.I hate TT its looks s**t, it's an added job that I can do without unless it's the only way, give me TNC-S and PME any day.
Well for me it's PME, and in our area it's pretty available everywhere even out in the Cotswold sticks where they have a lot of O/H lines every 3rd pole has a spike down.it looks as bad as the person that installed it, myself? I much prefer function over form, making it look good is simply a by-product of good workmanship
so which is it? PME, or TNCS, that you prefer?
well thats just pi55 poor workmanship, it should be flush with the surrounding area,Well for me it's PME, and in our area it's pretty available everywhere even out in the Cotswold sticks where they have a lot of O/H lines every 3rd pole has a spike down.They are pretty strict on the 0.35 though.
My rods are the dogs, but I only seem to do one every 5 years or so, in fact today I went to cut one out (not mine) as Scottish and Southern had provided PME at 0.16 and he wanted it removed from outside his front door and I mean right outside, about 100mm to the side of the frame, although he said it was handy for scraping mud off his shoes.
