Wiring from DY-107 to Heatmiser NeoStat-e V2, only 3 wires? Is L1 = LOAD?
Steve Mitch
Oct 13, 2024
Hi, my old thermostat/controller (DY-107) only has 3 wires as per the image (which is the lower left in the diagram), Live, Neutral and L1 (black) and is for electric underfloor heating.
The new replacement is a Heatmiser neostat-e v2 and i'm assuming it should take those 3 wires as L (Live) [far right], N (Neutral) [3rd from right] and the black from the old one (L1) going to the LOAD (2nd from right) on the neostat
Is this correct? (L1 = LOAD)??
The individual rooms have heatmiser DS1-L V2's with sensors in them for room stat temperature controls.
The neostat-e v2 will connect wirelessly to a neohub for controlling
Thanks for your reply, my concern was whether the neostat-e v2 going in, would need that taped up blue (2nd neutral) to be connected to the return LOAD? The 'N' in the middle connector on the neostat-e v2?
thank you
Write your reply...
