extension15
Distinguished Member
- Feb 13, 2008
- 1,658
- 0
Anyway, I often work without a break..
But that's another thread...
:^O
:^O
I have a split end screwdriver that widens out when you push a little slider down so holds the screw tight for the hot work,It`s also a way of doing it live Pray
Thought no sleeve on cpc was code 1!I have a split end screwdriver that widens out when you push a little slider down so holds the screw tight for the hot work, I dont sleeve the earth when I do it this way, :|
I usually have a smirky in corner o my mouth when Im working with the juice by the way,
why is this a no smoking forum anyway? we got the alkies covered Guiness Drink
Theres a bus shelter thingy at the back of Theorys cave! :|I have a split end screwdriver that widens out when you push a little slider down so holds the screw tight for the hot work, I dont sleeve the earth when I do it this way, :|
ah well..Thought no sleeve on cpc was code 1!
And my miniature horse GREW BIG!Just when you think you are picking it up.........JB's accessable
Sleve on earth
Socket in a bathroom
specs goes and points out the reality. My electrical illusions are shattered
while its enclosed in the JB its just like it was in the cable, enclosed so doesnt need any sleeving.! ?:|Thought no sleeve on cpc was code 1!
Now you wouldn't be saying that if it was 'enclosed' in a socket, would you?while its enclosed in the JB its just like it was in the cable, enclosed so doesnt need any sleeving.! ?:|
code 4Now you wouldn't be saying that if it was 'enclosed' in a socket, would you?
Because it's been in the regs for quite a while..So why do you chaps bother to sleeve it atall?
Since when??? I know of at least 5 members who like a ciggie.I have a split end screwdriver that widens out when you push a little slider down so holds the screw tight for the hot work, I dont sleeve the earth when I do it this way, :|
I would suggest probably to comply with....So why do you chaps bother to sleeve it atall?
Code 1... NO sheathing on CPC???I would give it a code 1, it is a dangerous as exporting pme
:S:S:SI would give it a code 1, it is a dangerous as exporting pme
nah! the regsiy book dont ask for that... only at terminations.:S:S:SApplaud SmileyApplaud SmileyApplaud Smiley
sleeved for identification purposes. ?:|
still dont think it needs sleeved in this manner, or do we push some sleeving down between the T&E too.?
I believe a J-box is a point of termination?514.3.2 Every core of a cable shall be identifiable at its terminations and preferably throughout its length....
skilled or instructed persons surely' date='? who else should be opening or inspecting a JB.?
[/quote']
Any DIY BOB doing a legitimate addition to his bedroom light maybe?
or repairing that bit of damaged cable the mice chewed though in the loft?
non part-P, non notifiable.. all pucka and Ok for non-skilled "Captain DIY" savin his pennies during the credit crunch!! :_|
below a bath out of zones' date=' requires the use of a tool and all those exceptions. ?:| ? :| ?:| ? :|
one for NIC perhaps?[/quote']
Still sill a fair few of them J/Boxes with a screw top lid... just twist it round.. off it falls...
maybe again up in the loft where they have boarded & loft ladder to stick all the junk up there...
easy access, no tools, no skill needed, no identification! ?:|
And of course you could then get trapped with the dodgy two-way landing-hall switching....
where someone has used a CPC as a switched live for the landing or vice-versa!!!
just throwin a few pebbles in the pond to watch the ripples!!! :| :^O :^O:^O
Guiness DrinkGuiness DrinkGuiness DrinkGuiness Drink
Still Code 4....
Don't comply... But not major dangerous!!!
