You have lost me as in one statement you say there is no CPC to the switch then you say there is a CPC in the box?The old Wooden switch boxes with metal screws? Code 1? No cpc to class 1 switch? There is a cpc in the box but obviously no connection!
But the screws don't tend to be within the "enclosure" with wodden backboxes..Well the switch is a standard plastic one but the danger lies with the metal screws becoming live as they cannot be earthed!
In that case no code for cpc (assumed it was metal), but still code the wooden back box.Well the switch is a standard plastic one but the danger lies with the metal screws becoming live as they cannot be earthed!
When it fails................. like yours. You have tested with combined LN to earth?Also when does low IR become a code 1? Got circuits with 0.06 and 0.00
no requirement for the earth to actually be connected to a terminal if device is class II. common in plastic boxes with light switch to make sleeve longer than the earth, to cover it. then fold over to hold sleeving in place. however, if earth continuity is req'd (like another outgoing cable), then the earths should be in a connectorThe old Wooden switch boxes with metal screws? Code 1? No cpc to class 1 switch? There is a cpc in the box but obviously no connection!
