Electricbox
Hey guys
I have encountered a strange problem today. When i gently touch the top part of an Xbox 360 slim and a grounded part of a PC, i get a small tingle in my fingers.
I have a cheap 12-250v AC mains tester, which i used to see if it would show anything strange.
Firstly, I tested if the tester works correctly. I used it to probe the 12V molex connector inside a pc (DC). It showed correct readings of 12V
Then I decided to use the tester on the top (metalic) part of the Xbox 360 slim, It shows 110v...
Same hapens with the power connector that goes to the xbox
The label on the xbox psu says that it outputs 5V and 12v
I'm a rookie when it comes to electricity, so what is happening here?
