you trying to steal work off me! :red cardFor the right price I'll come and sort it out. I can do Y plans in my sleep!
bad day explode
Do I really need to answer this!?You should check you have a "hot water off" signal correctly wired and working. You've been asked twice (above) about this and not answered, which leads me to suspect you don't understand the significance of this signal in a Y plan.
Hi all
Looked at a basic wiring set-up with programmer (dual channel), mid position valve, cylinder stat (no room stat) and Keston boiler. Heating engineer stumped so I had a look. If CH is selected at programmer the boiler fires as it should; when CH is set to off - the boiler remains on? Measured 89V at switched live. I know Honeywell valves 'leak' a bit of voltage - not normally enough for this to happen. Heating engineer had replaced the valve twice. What's occurring?
I understand how to wire a system - anyone else had this errant voltage on white wire when heating switches off. Its obviously enough to keep the boiler running!
It is very difficult for our forum members to answer anyones questions when the person asking the question fails to answer the simple logical questions being asked by those who are trying to help answer the problem in hand. The white wire is an input; to drive the valve either to the mid position (heat & Water) or the the fully driven position (heating only). The hot water electrical signal bypasses the valve completely going via the cylinder stat directly to the boiler, (commoned to the valve output orange on route). This voltage at the orange can back feed through the diode & resistors and micro switches inside the valve to give an "apparent input" voltage present on the White when the heating is off, due to the fact that the valve is in the home position with no switches operated. From the limited information you have give it sounds as though it is wired incorrectly, the big clue is the fact that 3 valves have been fitted with no success and you do not sound as though you have any awareness of how the 3-port valve operates, or stall's itself in the mid position by use of one or two 230v input signals. I can only suggests you actually answer some of the questions or it is pointless trying to continue this problem.yes, you do, cos you have left a system with an electrical fault and are not answering the simple questions put to you by people trying to help,
we're sparks, not Derek Acoiras mates.
What are you calling 230v sw live out? is this at the programmer or then orange valve wire? As has already been asked where is your 230v out signal for hot water off going. It is no good saying 'Heating off' or 'Heating on' without also saying the state of the water on/off relative to this. Water on+Heat on has to force the valve to stall mid-way, 109v is approx half 230v so sounds like a very typical stall voltage. To drive the valve fully for heating only the water off 230v is needed. From all the information you have give is does sound like a wiring fault. Have you got water off & heating off output connections crossed at the programmer? Some make of programmer have a non sequential water on/off heat on/off terminal arrangement.Quick update - visited premises again today. Heating engineer changed valve for another Honeywell 3 way. Same problem. All connections to boiler removed. Cylinder stat removed. No room stat. Hot water on 230V at sw live out. Hot water off 0V at sw live. Heating on 230V. Heating off 109V. Did notice that the valve seems to stop momentarlly at 109V on the way to 230V when the heating is switched. I'm stumped. Definately not the boiler. Wiring centre is all good. Tried replacement programmer. Only thing it could be is a duff batch of Honeywell valves? Engineer is gonna try it with a Drayton valve. I'll let you know the outcome.
Indeed as it is just a handful of series or parallel switches to operate a load. Which should be no more complex to fault find than two or three way light switching, to an electrically competent person.its really not rocket science,
anyone that claims to be an electrician and cannot wire a heating system, be it Y plan, S plan or whatever is not only fooling themselves,
they are a liar.
Had noted this Steps, which is why I don't understand the OP's difficulty with this, a simple admission that he needed a drawing as reference then surely he'd had the information hat he need to diagnose the fault?I.did.offer a.wiring diagram, but was dismissed as it was basic electrics.
Firstly - apologies if I was a tad rude earlier in the thread; been a long few weeks. As you know I've been a member of the forum a long time and always appreciate all your help.I do loads of Y plans, (and other systems) and would say Im pretty confident with any of them,
but I keep a copy of honeywells [very easy to follow] wiring diagram in the van all the time so if I do have an issue I can get it out and double check what I thought I knew anyway.
always good sometimes to trace it back in black and white rather than whats in your head.
Not yet - it's being looked at next week by someone else. I will post the outcome.So are you saying it is now solved ?
Not clear from that post?opcorn
:shakeheadNot yet - it's being looked at next week by someone else. I will post the outcome.
So the Honeywell course is not that good then?even trained on a Honeywell course
not being funny,Firstly - apologies if I was a tad rude earlier in the thread; been a long few weeks. As you know I've been a member of the forum a long time and always appreciate all your help.
Like Steps I always have a bunch of manuals to hand; even trained on a Honeywell course. Usually install wiring for Veissmann boilers. This problem just had me stumped. Basically the original Keston service bloke turned up to service the boiler - bit later on the fault occured. He then changed the valve a couple of times. Then I had a look. All the wiring is good at the wiring centre, the programmer, the cylinder stat - I re-terminated all connections.
