Now now!!!! I have got a nice shiny new Megger 1730!! You can plug the 13A plug thingy in if you want, but the leads coming from it are all separate anyway, so you can stick them in any hole you like!! [on the meter!!!!]
All tests apart from the earth rod resistance test only use two leads. The "high" current loop test, and the "low" current "no trip" one, use the same leads [or the "plug" thingy] but with the leads stuck in different holes on the meter. If you try to do, say, a no trip earth loop test, but you have the leads in the wrong holes on the meter, the meter will show "CON" on its display, so you know you have made a mistake!!
If you want to though, you can use the plug thingy with all three leads plugged in at the same time and do a "normal" L/N loop impedance and then a "no trip" low current, L/E one, just by turning a ****, no leads to move!
There is a "slidey" thing covering the holes, but all this does is to stop you trying to use the meter at the same time as the charger is plugged in, [Remember, it has rechargable batteries in it]
Megger have made a video of their meter, but it does make it look more complicated to use than it really is. The manual is not bad, but could be improved on though. Still, at least it is not written in Fluke's version of "Pidgin English" so that is something..
I am really pleased with my Megger, i have never used a Fluke, so i cannot comment, but i have a Fluke phase rotation meter, and that is REALLY nice, and i nearly bought a Fluke voltage probe, and that had a really nice "feel" to it i must say. Soooo, Fluke, Megger, all comes down to personal choice i suppose.
Still, if it does explode, at least i cannot say i was not warned!!!
john...
---------- Post Auto-Merged at 14:48 ---------- Previous post was made at 14:45 ----------
How funny is that!!! When i tried to use a four letter word to describe the "handle" on a rotary control on the meter, [word starts with a "K"] the "system" thought i was being rude and "bleeped" it out!!!
john!!
