- Oct 22, 2010
- 14,620
- 1,170
So, today my evaluation set arrived, ready for a beasting
The case is well made, if not a little on the chunky side. Space inside for a torque handle and a setting tool. If the handles were all fitted with a bit there would still not be enough space to accomodate all the available bits. The case is quite large and would have benefitted from some form of handle as it takes a "full grip" to hold/carry it
Kit contains
1 of each......POZI plus/minus numbers 1 and 2. NOT PHILIPS HEAD VERSION, TWO SLOTTED, and unfortunately in my case TWO Number 2 standard POZI bits....instead of a 1 and 2
T handle, standard handle
Both handles are chunky, feel 'right' in the hand with a positive lock for the bits. It does not feel like they will fall out in use...unlike thw WIHA version
The T handle feels like you could easily shear a head off as the grip is so good...in fact it is probably the best I have used....AND VDE!
Two different methods of releasing the blades aon the two supplied handles...i would have thought a single standard method was better. BUT they both feel good
I have tried the blades within about 25 different types of MCB, RCBO which I have in stock...a slight issue arose.
There is quite a lot of insulation around the tip and this prevents the blade entering the tunnel terminals on
A). The neutral of a CED RCBO
B). Top terminal on the old style 'coloured toggle' Wylex NSB MCBs
C). Top terminal on the MEM RCD with the removable module
D). A few tunnel style terminals on sockets...cannot remember which
. These are comparisons with my WIHA set
A lack of available bits could let this set down as there does not appear to be an option for Philips plus/minus, Torx or Hex
To be fair, there is no Philips plus/minus in my Wiha set, neither is there a hex option ( BUT i have not researched this as I have other kit which will do the job)
Additionaly the space taken up by this set is a lot greater than the Wiha offering.
relative dimensions shown for comparison
I have compared this with Wiha as this is what I have for day to day use. The multiset lives in my Veto MC bag and the torque handle and setting tool live in the same bag BUT different compartment as I do not use it all the time
I Will,try it on site over the next week.
If anyone wants me to try something "specific".....but legal, then post on here and I will give it a shot if feasible
Kit contains
