Mft calibration prices
David1906
Oct 8, 2024
13
Essex
Hi all, I’m about to get my first mft calibrated, I’ve been looking at different companies and the prices vary from roughly 80 to 150 . Is this the right price range ? And any recommendations for a good price and quick turnaround would be appreciated thank you .
HFM?????!
I get mine done when wholesalers have a Trade day. Last time it was about £40, that was 2 months ago
That's cheap. I normally pay around £85, we have a company that does calibration work in Plymouth. They have a proper test lab that reminds me of when I worked in a similar environment calibrating and maintaining test gear as part of my apprenticeship.
I use a local test instrument supplier that has a UKAS accredited calibration lab, usually around a 48 hour turnround which allows for a 24 hour aclimatisation prior to calibration to ensure accuracy of the calibration costs about £80 - £90 I think
Never sure about these wholesaler trade day calibrations as there are potentially too many variables which could affect the outcome / accuracy of the calibration
As well as getting an annual calibration throughout the year I periodically verify the meter with a calibration check box
We sent a batch of meters to a calibration day which included by mistake an insulation resistance/continuity tester which didn't work on continuity. Came back with a Certificate saying all was well but still didn't work.
I normally keep my eye open for wholesalers having calibration days - I think I last paid £70 inc VAT
I try to avoid sending my mft away as it’s never that quick to come back
How do you find when wholesalers are having calibration days , i Googled but couldn’t find anything
Why does your tester need calibration, it doesn’t, it needs testing against a known value, do you imagine they strip down your MFT and alter the values not at, all they do test against a set of known values which you can do at home with a check box, I’ve an niceic one that I use
CPS membership requires you to produce a calibration yearly
I bought a secondhand mft and I will be using it on site and the calibration has run out , we have to have a calibration certificate when using any mft on commercial and residential site work, which is what I do for a living 👍
No offence but you obviously don’t know the rules and regulations with using mft’s
I always use CEF.
I never use them for anything else as they are so expensive, but for some reason they are cheap to do MFT calibrations. £55 (Inc Vat) last year.
how do you book it in mate , looked on their website and nothing about calibration. Did you ring up or take it in to their shop
