- Feb 27, 2008
- 11,018
- 0
That was decided at start may be a problem getting it round a tight bend if needed though.you may wanna go with a 25mm conduit with 10mm T&E.
You are correct (if) using that table 41.1 however 411.3.2.3 explains why for a circuit above 32 amps can have a disconection time "not exceeding" 5 s.max disconnection time is .2secs if using that tabletn Uo 240v ac
+ add SL
concurYou are correct (if) using that table 41.1 however 411.3.2.3 explains why for a circuit above 32 amps can have a disconection time "not exceeding" 5 s.
And how would you propose he complies with part C of the building regs? And what if insulation is installed?can you not fish it up the cavity?
what does part c say?And how would you propose he complies with part C of the building regs? And what if insulation is installed?
Never mind Part C, Andy's link in post #4 covers the subject adequately.what does part c say?so what if it has insulation all the info is in brb for derating
thats a external cavity i meant an internal one headbangNever mind Part C, Andy's link in post #4 covers the subject adequately.
Ahh, I thought you meant external cavity too.thats a external cavity i meant an internal one headbang you can get your cable from loft down cavity wall (partition?) to under floor boards then across joists to above db
Externally, yes. It really should be in black conduit but white is better than none.Conduit fine with me, even clipped if it is above a height were it is likely to be damaged. Would you question it if it was 1.5
ah ha my very point. you could but you won't because you have a conscience so why not apply it further?nope i could put it in the bathroom outside the zones
more chance of wet fingers
